New From San Antonio
kf95087
WELCOME EVERONE. I OWN A 2009 CHEVY SILVERADO, 1500, LTZ, -6 INCH LIFT, 35 WHEELS, AND 4.56 GEARS. A MONTH AGO, THE 5.3 WAS SWAPPED-OUT FOR A 6.2L-NEW CRATE ENGINE. I KEPT THE VOLANT CAI AND MAGNAFLOW EXHAUST AND ADDED LONG TUBE PACESETTER HEADERS. THE 5.3'S ECM WAS COMPATIBLE WITH THE 6.2L. IN FACT, 5.3 ECM IS THE SAME PART NUMBER FOR THE 6.2L ECM. I'VE ENCOUNTERED A SNAG, IN WHICH THE VVT IS NOT WORKING. WITH THAT I AM TRYING TO FIGURE OUT HOW TO ACTIVATE THE VVT. TWO POSSIBILITIES COME TO MIND. THE 5.3 WIRING HARNESS NEEDS ADDITIONAL WIRING TO ACCOMODATE THE VVT OR THE ECM NEEDS TO BE REPROGRAMMED. ANY SUGGESTIONS WOULD BE APPRECIATED. I'LL POST PICTURES OF THE TRUCK WITHIN A WEEK. THE 6.2L RUNS GREAT.
KEITH
You need to have the ECM programmed for the 6.2L as well as the 6.2L harness. Running it on the 5.3L programming is a bit unsafe.
if u dont mind me asking,how much did that 6.2 run you? im also from san antonio,and i was looking into swapping my 5.3 for the 6.2 but wasnt sure if it was worth it for the most likely ,hefty price tag
Also, if you don't mind me asking, why would you waste that much time/money swapping out this in such a new truck (or was the 5.3 thrashed). Seems like a lot for a 2009 when you could have just bought a new one with the 6.2.
im currious on why you switched as well instead of buying a new truck. however i can appreciate what you did cause it sounds like a fun project. course with that money you coulda just supercharged/turboed the 5.3. haha. anywho, good luck and make sure to get the ecm re programed or you may do crazy damage to that brand new 6.2.
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 857 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
