00 2500 Cargo Van
we have this work van its a 2000 2500 van with the 350v8 it stalled out on one of our employees when getting off the freeway. it then wouldent start back up. ill be hauling it back to our shop in a few days upon a quick inspection the oil is full the antifreeze is low. with the battery fully charged it cranks fast for a few revolutions and then the cranking slows way down. it acts almost as if the timming is way out. i tryed hitting it with a little starting fluid to rule out fuel pump/delivery doing that it will backfire out the intake. it has good strong spark, i tryed rotating the distributer as much as allowed without pulling it and restabing it. any idea's what is most likly wrong with it?
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
