So I was going over some theories in my head. When you do a body lift can you lift the engine at all? If so I would be able to fit headers on the noma without shaving at the suspension houseing or tower. Whatever it is called. Also with a body lift, does the steering stabilizer move at all? That was another issue I ran into with putting headers on it.
Thanks.
Only the body will be raised and there will be a steering shaft extension. The issues you are having with clearances of hard parts will still be there. Typically the only time body lifts are used for clearing new parts are for motor/tranny swaps.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
