Question About My 2" Rc Lift I Completed
Ok, so I am a noob, big time. I installed a 2" RC leveling kit on my Sierra. I put both washers under the bolt head instead of one under the bolt head and one under the nut. Do I need to go back and switch it so each end has a washer or is it fine do you think?
I would switch it so each end has a washer under it. Just my .02 :uhoh:
If you don't switch it you'll worry about it regardless of what we say. Switch it.
So true...
If I just switch the bolts around I shouldn't have to get another alignment right? Just leave everything else along and put the bolts in properly?
So true...
Just get a jack under it and completely remove and retighten one bolt at a time. Nothing should move at all so no new alignment would be needed. Also, on most kits the instructions state to put the nut on the top and insert the bolt from the bottom.
    FiLo
    FiLo
  • Who's Online   4 Members, 0 Anonymous, 598 Guests (See full list)
