billyboy2
My truck is a 07 gmt900 and I want to try and put some 295 70 17 with aftermarket rims -12 offset and a 2" leveling kit...Am I dreaming that it won't rub...I'm will to trim some!!
I think your dreaming... They are 33.26" diameter. You'll be metal not plastic to make those fit. Drop down to a 285 and you'll be fine. :thumbs:
Ok. If I go down 285 I'll be going with 285/65/18... Can I still use -12mm offset?
