2009 1500 Ext 4x4 Max
It's a 2008 model not 2009... dammit, I even put 2009 in my username. F@#*
I know it's probably been answered already, I just bought a 2008 Silverado ext 4x4 with a 5.3l with a factory tow package. I was just curious on what the max is that it could tow.
I ran the vin through the decoder and found this:
Z82 TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH) PROVISION FOR HD TRAILER EQUIP(Z82)
C5W GVW RATING(7000 LBS) 7000 LB GVWR(C5W)
GT4 AXLE,REAR,3.73 RATIO 3.73R(GT4)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
KNP COOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP)
LY5 ENGINE GAS,8 CYL,5.3L,SFI,IRON,CYLINDER DEACTIVATION,GM 5.3J W/CYL DEACTVN(LY5)
A standard bed would be 7500lbs a long bed would be 7300lbs for ext cab 4x4 and 3.73 gears
    bellssn690
    bellssn690
  • Who's Online   3 Members, 1 Anonymous, 532 Guests (See full list)
