To Much For A 1500hd?
caesar2
Hi all. We are looking at buying a fith wheel trailer. The dry weight of the trailer is 8,250lbs, and the hitch pin weight is 1400lbs. and the gross weight fully loaded is 11670lbs. From what I understand the max mine can pull iss 9990lbs. The weight of the water/black/grey comined if full would be 1200+lbs alone. I do not plan on going long distance traveling, most of are camping is within 30-40 miles. The truck is an '03 chevy 1500HD with 6.0 liter and 3.73 rear end. I realize I won't be setting any spead records, but am I safe pulling this much? Thanks for any info/ opinions.
Rick
You should be fine. You basically have a 2500 regular. The gvwr is 8600 lbs so the weight of the truck plus gear and whatever is in the bed. I am 100% sure your fine with the 1400lb pin weight. as far as total tow rating your close to the line there. But if your not doing it every day your not gonna hurt anything.
I don't think you'd have probelms with it. Just make sure your using a trailer brake and make sure your trans/rear fluid is up to par. Keep your tire pressures withing spec on the truck and the trailer.
Have fun camping. :sigh:
If the tire placard, on your driver's door jam, states 9900 is max trailer weight, then that's it. I certainly wouldn't over load that by nearly a ton no matter how short of a drive that I had towing that weight. Just my opinion.
I guess I am confused then.
He said empty trilaer weight is 8250 + 1200ish for water/crap(lol). Thats around 9500. So it's under the 9900 lb trailer weight. There is 1400 lbs on the 5th wheel pin which was under his 2500lb ish weight he can handle in the bed ( assuming his gvwr is 8600lb which it should be) the truck probably sets at about 6k with driver and fuel. Maybe 7k with more people and gear. So that still gives him 1600lbs in the bed which he should still be ok.
So from what I can see he is right under the max limit all the way around. Not ideal for lots of towing but still under the weighted ratings.
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
    • Sounds like a smart reasonable person with common sense. Bill O’Riley never said he was just a journalist, by the way.
    • It's like saying Bill O'Reilly is "just" a journalist.         Lauren Fix, widely known as "The Car Coach," is a prominent automotive journalist, television personality, and self-identified conservative. She is a frequent contributor to right-leaning networks and platforms, offering commentary that intersects the automotive industry, consumer economics, and conservative political perspectives. [1, 2, 3] Media and Commentary Network Contributions: Fix serves as the National Automotive Correspondent for Newsmax and is a frequent guest on Fox News and Fox Business. Video Platforms: She has contributed to PragerU, where she has hosted videos critiquing government mandates on vehicles. [1, 2, 3] Core Positions Anti-EV Mandates & Fuel Policies: Fix regularly critiques government subsidies and mandates for electric vehicles (EVs), framing them as impractical and burdensome to the average consumer. She advocates for consumer choice and supports traditional internal combustion engine vehicles. [1, 2, 3] Economic Analysis: Her commentary often emphasizes the impacts of fuel prices, inflation, and federal regulations on drivers. [1, 2, 3] Political Alignment: On her public channels, she actively supports deregulation, "drill baby drill" energy policies, and the removal of government restrictions on auto sales and manufacturing. [1, 2] For analysis from Lauren Fix on how consumer automotive choices can align with political leanings:
    • Wouldn't swapping out the original AFM/DFM parts for a complete Delete Kit be the best route to go if one could afford to go that route?
    • It comes with directions but yes, generally, it's the same.  Also, get you the dipstick stuff to install dipstick so you have one.
