Looking For Tips And Advice Re: Parking Brake
2000 5.3 ecsb 4x4
The drivers side parking-brake cable is routed under the diff. tube. As a result the cable sheath has been damaged enough to let water and dirt into it. Causing cable to sieze, and brakes to be stuck on.
My question is this: Is there a better way to route the cable so it will not be as likely to get damaged.
Also; Is there a way to keep dirt from building-up inside the Parking-Brake actuators ( mechanical wheel cylinders ) ?
Thanks for reading!!
