Towing Miorrors On Reg Cab?
NickB
I put the OEM towing mirrors on my truck and I love them!! I have no idea how I drove without them!!
mines lifted and i put them on they look orgasmic, i cant believe i drove around lifted without them before, i have a problem wtih the truck bein so tall and short that the way i have to angle the lower mirrors i get blind spots though. sorry no pics idk where the hell my camera went
    bellssn690
    bellssn690
  • Who's Online   3 Members, 1 Anonymous, 532 Guests (See full list)
