Pioneer Deh-p6100bt
Pioneer DEH-P6100BT head unit with adapter and wiring to fit '07 and newer P/U dash w/o console This unit has remote, sub-woofer line out conectors, blue tooth, USB, Aux input, and detachable face. Also included is the AXXES 06 up GM LAN adapter to control Onstar and turn signal relay, Pioneer GEX-P920XM XM radio tuner with antenna, and Pioneer GEX P10HD HD radio receiver.
$250 + shipping
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
