F/s 1983 Toyota Landcruiser Fj60
here is my 1983 toyota landcruiser, great car. it has 155,640 miles on it. the engine was rebuilt at 120,000 miles, everything runs great on it, it has new carpet, new tuffy center console, interior overall is good condition, its has new gas tank, new clutch, new brakes, new 1inch suspension me and my dad put on it. new rear main seal. Like i said it runs great. the AC doesnt work but we have the compressor. maybe 6-800 worth of body damage on the car which is the dent in the front bumper and the back bumper where i left it out of gear and i rolled down my drive way and hit the neighbors truck..... yea. 2500 OBO
if you or someone you know is interested PM me please.
  • 3 weeks later...
Michael, I am looking to pick up a Cruiser for parts to further refurb my fj. It looks like you are in South Carolina, which would be a little bit of a haul from Missouri, but if the engine is in good shape (with the rebuild at 120,000) then I would consider making the trip. The travel cost would be a bit, but your cruiser is exactly what I am looking for. Send me a message back if you have not already sold the Cruiser! Thanks B-Ray
    AidenVorpagel
    AidenVorpagel
  • Who's Online   0 Members, 0 Anonymous, 1,299 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
