Wtt 2nd Row Captains Chairs
i'm looking to trade out the 2nd row captains chairs from my 2003 Yukon for a 70/30 split bench (2001-2006). interior color code is 92 (shale/pewter). i'm nearing 120k miles on the clock, but i'd estimate the chairs have less than 40k miles of actual use. they've spent most of their lives folded down. hoping to find a deal within a few hours drive of 18603. i can email pictures to any interested parties.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
