99 K2500 6.0l No Start
Greetings, all. I'm having a bit of trouble with my father's 99 K2500 and was hoping y'all might be of some assistance.
Currently, this truck is stranded at my new residence (that I have yet to move into). The truck will click when trying to start, but the engine won't even turn over. All the lights and accessories come on, but no cranking. This happened to us once before and it started fine with a freshly charged battery, but this time that won't even do it. All the fuses and relays check out, the terminal connections were good and tight, but it just keeps clicking.
Some extra info on this truck: 99 K2500 6.0L, half-arsed incomplete NP246 to NP243 swap (previous owner), 4L80E transmission
I did some searching on the board and came across reference to internally corroded battery cables, which will be our next check. In the event that the cables check out, what would be the next step? Beating on the starter is a given, but I was wondering if there is another quirk that these trucks have?
Oh, and, the shift indicator works properly and shows the truck in park. We've tried shifting into neutral and trying to start, same results. Really need to get this truck going so I can use it to move! :cheers:
Thanks in advance!
I can't offer any more, but I think your going in the right direction. Make sure the ground strap to the frame is there.
Mark
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 404 Guests (See full list)
