4l60e Advise
gamitch11
VEHICLE: 2000 Silverado , 2 wheel drive, 5.8L, mileage=106,000
HERE'S WHAT HAPPENED: Cooler line became disconnected, and dumped the transmission fluid at highway speed. Wife pulled over and stopped immediately (called me for help). Never had any problems with the transmission before, changed fluid an filter at 60,000 miles.
QUESTIONS:
Do you think there was any permanent damage done?
What's the possibility that I'll get lucky and be able to just be able to reattach the cooler line and put new transmission fluid in it and the transmission be OK?
Thanks for advise,
Gary Mitchell
As long as she pulled over as soon as she saw clouds of smoke pouring out the back, you should be fine. If she drove until the truck started slipping ... then kept trying to go, then there's a possibility of oil starvation issues internally.
Just re-connect the lines, fill it up with ATF again & go for a drive - that's about all you can do. Listen for any whining or unusual sounds, and be alert of any strange shifting characteristics. Let us know how you make out. Good luck!
when a tranny looses oil,the clutch pistons retract and the clutches disengage ,the pump is turning at engine speed and and still has some lube and there is no way to damage it unless the engine idles along time after the truck is on the side of the road ....
fill it and go for a rip as Smitty said
    appletrav
    appletrav
  • Who's Online   0 Members, 1 Anonymous, 499 Guests (See full list)
