Replaced Blower Motor Resistor, Now Blower Not Working
rwilly
Hey all, I did some reading on this problem on this forum and others, and thought I had it figured out, but must not have. Looking forward to hearing your suggestions on this -- thanks!
Vehicle: 2005 Sierra SLT Crew Cab 4WD
Original problem: Blower motor jumped up to high speed all on its own one morning, then the blower motor continued to run, even when the vehicle was shut off - ran the battery dead. I installed a new blower motor resistor (bought from my local GM dealer), and thought I had fixed the problem - everything worked as it should for about 2 days.
New Problem: This morning, nothing blowing at all. Haven't had time to open up and look for any probems with the resistor I installed this weekend, but I am pretty sure everything (connections) are good.
Any ideas?
GM is supposed to be repairing these free of charge, I believe. "04-'07 models. Might be some other criteria, like manual controls vs automatic
If that was your issue, you should have replaced the resistor as well as the wiring harness connection to it. Had mine done at the dealer under the 'special warranty extension'.
I would take it to the dealer to have it checked out under the special warranty on the blower motor resistor. I wouldn't mention the fact that you have tried to fix it yourself as they will probably try to blame it on you! Hopefully they can get it lined out for you.
Check the blower motor fuse. If you replaced the resistor without pulling the fuse, you may have blown the fuse.
If you didn't change the connector, it may be fried. If you look at the connector and it looks blackish in areas and/or slightly melted, the connector may be shorting inside.
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
