Man Hits Lottery-TWICE
TxDoc
Man beats one in 23 trillion odds to win lottery twice in one day
By The Associated Press
(12/12/02 - BELMONT, Calif.) — Angelo Gallina beat the odds and then some.
In a single day, he won the $17 million SuperLotto Plus jackpot and the $126,000 Fantasy 5 top prize.
"I think I'll eat cake," Gallina told lottery officials after his Nov. 20 wins. He said he would also buy a new car and a home for his grown children.
State lottery officials put the odds for the SuperLotto contest win at 1-in-41 million. The odds of winning the separate Fantasy 5 contest were 1-in-575,000.
Figuring out the odds of one person winning both draws on the same day requires a calculator and lots of zeros.
"One in 23 trillion," said Mike Orkin, a professor of statistics at California State University at Hayward, who arrived at the number by multiplying 41 million by 575,000.
Man, I've been in a lotto pool at work for like 2 years.  We are in it twice a week for the Super Lotto drawing.
As soon as we hit it drinks are on me!  Cheers!   :wtf:
    Gkistler
    Gkistler
  • Who's Online   2 Members, 0 Anonymous, 892 Guests (See full list)
