Viper Remote Start
CamZ71
I had a viper remote start on my 01 s10 and then moved it to my 03 silverado for 5 more years and never once had an issue. It always worked flawless and had awesome range.
I'd highly recommend it.
I think the Viper SmartStart is an add-on. You still need a Viper Remote Start system, then I think the SmartStart adds the ability to integrate with a smart phone.
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 1 Anonymous, 591 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
