Brake Line Help
Have to ask what is everything doing when there brake lines go? I see Classic Tube offers an entire kit. Is this the way to go?
I didn't wait until mine broke. I ordered from classic tube and changed the brake hoses as well. It took a day and a half to replace everything, flush, and fill with fluid. I like the classic tube kit, it fits well, however be smart about how the lines route to the ABS unit. Some lines you have to put on before others.
I looked at classic tube when I needed to replace mine, but they didn't have my truck listed. I ended up buying bulk rolls of stainless steel brake line from Summit Racing. If you are careful, you can bend it into shape by hand. I started replacing one line at a time, but ended up having to cut all the lines at the ABS unit, remove the ABS unit, and use a pipe wrench to get the old lines out. I also replaced all of my flex lines with braided stainless steel lines at the same time.
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 473 Guests (See full list)
