1999 Chevy Blazer - needs work
TYPE GENDY
Posting this up for my mom, who bought this almost new i believe. She kept it very well maintained.
Body in great conditon, but has rust. 165kmi, 4x4 auto. Not running, but not sure why, may need new engine? Many new / recent parts including Front and rear Brake pads, front and rear rotors, rear leaf spring shackle kit, new fuel pump, new fuel line replacements, new A/C compressor...
Must be towed away Asking $1900
