Rear audio controls.
Ok guys, i recently upgraded my center console to the full LTZ console, however the one i ordered was supposed to have just the 'cubby hole' on the back part above the flip-down cupholders. However they sent me one with the rear audio controls instead. I listed the rear audio controls and all the components that go with it for sale on here. But if no ones interested in them, i thought i might see if it is possible to wire the rear audio controls in to work with my truck? I have the harness that goes with the console, however i DO NOT have BOSE in my truck. I installed the factory navigation and just wired in an aftermarket amp to run the trucks speakers. So is there anyway to wire just the rear audio controls into my truck so that they'll work at least somehow the way they were meant to?
any help with this would be greatly appreciated
Thanks guys!
Unfortunately there is no way to wire in the rear audio controls without Bose.
Sorry.
Sorry.
but what if you swapped out the headunit for a bose factory navigation headunit and factory bose style amp? (everything is as bose is but the speakers arent bose.)
  • 1 month later...
good point, i have already done this, I swaped out my regular headunit for the OEM BOSE navigation, and the amp i have is the OEM BOSE one along with the harness for it...
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 562 Guests (See full list)
