Seat switch, down is up & up is down...?
Babyhauler
My seat switch has gone crazy.
I bumped the seat memory switch in my 05 LT Crew Cab the other day and it attacked me !!
The back pushed foward, the thigh support went up & the back dropped down, all the while it was mashing me into the steering wheel.I thought I was in Christine's sister.
Anyway, I adjusted everything back to normal except it felt like the thigh support was not going all the way down. It looked about right but did not feel the same. I jumped in my 02 and the front was down lower.
It would bottom out & the motor would stop like it is supposed too. No binding, grinding or straining to work. It sounded like the "off" or end of travel switch was working & turning it off.
I started removing the seat bottom today, but just got to remove the nuts for the front & slide it out of the back slots before I had leave. Took the wifes car & was gone too long to finish the seat tonight. Put it together and hit the switch.
Up on the front of the switch made the front go all the way down. Down made it go up, but not all the way. The back worked normal. I played with it some & it seems to have a halfway point where it changes. With the seat front halfway up, up on the switch is up & down is down, until it stops with about an inch to go. Then if I move the back of the switch a little, the front changes & up will lower the front the rest of the way down. Down will then raise it up some, wiggle the back, then up moves it all the way up.
Now, all I did was remove the nuts, no harnesses were undone. So I guess this must have been triggered when the seat attacked me.
Do I need a new switch, is it the sensors on the motors or do I need to just learn how to work my psycho switches?
Thanks for your help.
Babyhauler
GM used some real crappy switches on their late 90's to mid 2000's - wouldn't surprise me in the least if the switch was bad.
I had an "express UP" window on my '00 Jimmy - otherwise known as ... A GUILLOTINE! Don't stick your head out the window! :thumbs:
Was probably the switch ... but after a myriad of electrical gremlins in this pile, I parted it out. First vehicle I ever threw in the towel on. I couldn't take it anymore.
Babyhauler
take it in,get a diagnoses
I google'd this & it looks llike the seat control module has to be refreshed with new software from the dealer.
Anyone had this done?
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,331 Guests (See full list)
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
