Need A Console Measurement
I was wondering if anyone with this type of center jump seat could give me a measurement on how wide it is. I am trying to figure out if I can mod it to fit in place of the flip down arm rest on my GMT400.
Thanks in advance guys, if the width will work I'll be in the market for a light colored one.
Here's a pic of a black one I found on ebay.
Mine is 13 1/2 inches in that area
Many thanks I appreciate it, time for me to do some measuring now.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
