Speakers?
kurt1993
Awhile back i decided to do an audio upgrade even though i didnt know much about audio, and what sounds good, and how to do everything. i ended up with a midrange kenwood headunit with aux, usb, 3 pairs of preouts in the back, HD radio, and that's all fine and dandy but right now im trying to upgrade my rear speakers and as most of your know with extended cab trucks they came with 4x6s and they're awful. i was thinking about cutting the holes bigger and trying to fit 6x9s or whatever, but im worried about the door panels not being able to fit, and those panels have been off for a LOOONNNNGGGGG time now. I have a Polk PA660 4 channel amp that puts 75RMS to 4 speakers 2 alpines in the front and right now i currently have some polk 4x6s in the rear but they are blown.
soooo......
what should i do? better speakers all around, better amp? im happy with the head unit for now but the Alpine 6.5s up front are EH at best and the polks in the rear are blown and i dont know the amp was kind of cheap but im just a kid i dont make a ton of money.
Can i upgrade to a bigger size in the rear and still fit the panels on?
What do you guys recommend for speakers and amps?
Any information or whatever you can offer is appreciated.
Thanks,
-Kurt
I cut the rear ext doors on my '01 because I, like you, was unsatisfied with the 4x6s. Did a couple measurements, drew a couple lines, and took the jigsaw to them. Panels fit just fine with the 6.5"s on. The panel, at least on the '01, had more than enough spacing between the woofer. Sounded a heck of a lot better too. I had more of a problem trying to fit the 2 amps and the 6x9s somewhere in the cab then the 6.5"s.
I like my 4x6's. I have polks in mine. A 4" woofer and separate tweeter
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
i mean i had polk 4x6s hooked up to the amp and the amp just overpowered them i guess, there wasnt enough sound to make me happy so i turned the gain all the way up and blew them cause i was angry i guess
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 485 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
