what does this new code mean,? why so different ?
isnt "K" 4wd and "2" 3/4 ton ?
signed ,confused Rob ,,,ty
I don't know Rob, maybe K is for thousand? And the XX will be the year the vehicle came out? Or maybe some internal code that has no meaning. lol
The C/K designation for drive system quit in '98 I think. But I was in grade school then. :lol:
I know in my 04 it is 2gteC which is Canadian built half ton GMC 2wd. Then 19 which is extended cab. I havent seen a VIN breakdown of the 2014's yet
Sent from my Samsung Galaxy S4 using Tapatalk 4
    bellssn690
    bellssn690
  • Who's Online   3 Members, 1 Anonymous, 520 Guests (See full list)
