front end conversion on 02 GMC
In reality it will take at most, for you at least, new feame horns and grille assembly and fog lights if equipped.
Like mentioned above, you will need the 03-06 frame horns. You will have to cut yours off and replace them. You have two options, cut some off of a 03-06 in the junkyard and weld them on your truck, or buy some from LMC Truck or eBay that are made to be bolted on. I've seen this on other forums. Drill a few holes after you cut your original frame horns off and the new frame horns just bolt right on. Then you bolt up your bumper and you are good to go. The 03 grill is a direct swap, so no modifications needed there.
Current lights will work as they were the same from 99-07. The only lights that need to be from an 03 are the fogs
Thanks that helps a lot. I think the fog lights come with the bumper so would I have to rewire them or just put my bulbs in the new fog lights?
Depends on the setup. Sometimes they are plug and play sometimes it needs a cut and splice. I just read their site. "Factory fog light mounts" so you will need to get a set of 03-07c Sierra fogs
    ballencd
    ballencd
  • Who's Online   0 Members, 0 Anonymous, 414 Guests (See full list)
