6.0L oil pressure issue
jott5555
While driving down the road i got a P0521 Code and noticed the oil pressure gauge showed low (about 18PSI). I reset the code and installed a new pressure sending unit and screen just to be safe. I no longer have the code however my oil pressure is not the same as before the code. Currently I have 38ish PSI at start up and around 18 at idle when warm. Before this code it ran around 40 at idle. At the same time as sending unit i put in new Mobile1 5-20 Synthetic and a Mobile1 Filter. After the oil change i have noticed some slight lifter tick when cold in the morning.
How do I check the oil pressure with a mechanical gauge to verify i have low oil pressure and it is not the gauge. If it is low Oil pressure at the sending unit should i replace the pump and screen next? Is this a common issue? It seems i read more and more about spun cam bearings.
Truck info
07 Chevy Avalanche
6.0 w/ 84K
Thank you
I had a mechanic hook up a pressure gauge I had 80KPS at idle, 170KPA @ 2k & 220 KPA @ 3k. Are these numbers normal?
Correct its low... much lower then the 40 at idle I used to Have. I'm going to try a fluis this weekend if that dosnt work then I will replace the oil pump
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,259 Guests (See full list)
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
