Check engine light
racerx520
Last night my check engine light came back on, i'm figuring it has to do with the canister purge solenoid that i've replaced already (if thats the right part, the one near the fuel tank). After i scan it and find that it is that part, i was curious if there is a replacement which will hold up longer than the OEM part that keeps going that anyone knows about.
Thanks.
First things first, let's make sure that is the cause of the check engine light. If it is, sounds like a failure, and should be covered under the manufacturers warranty. Have you looked into that yet?
Thanks.
there is no "figuring" anything when a SES comes on ,,,it has to scanned first !!!!! and you get what u pay for in electrical parts ,,,the "vent" solenoid does fail and dirt roads cause it and the EVAP canister is full of dirt ,,,,,if the solenoid is only changed ,,it wont last long from my experience in rural Alberta ,,,,always replace the canister with the vent solenoid and relocate the filter to the engine compartment ,,,,lots of threads here on this subject as well,
reply back with the code if ya want ,,,,we'll be right here lol
  • 1 month later...
The "purge" is the one on/near the engine / intake manifold. The vent is in the rear. I image you are getting a P04** code. Let us know the actuall code number and word for word description. And what year/model is this?
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,180 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
