Ford eats it
Wingnut
Last night, we started getting a little freezing rain here in OK. Not a big thing really. But it just amazes me how people just don't think sometimes.
I'm driving along a four lane road close to my house, and there is a Ford Ranger "Edge" a bit ahead of me.
Came up on an overpass, and he didn't even slow down. Temp is in the 20s, freezing rain.......Retard.
He didn't make it 20 feet onto the bridge before he turned sideways, and smacked the concrete wall...From which he immediatly rebounded, and just so the other concrete barrier didn't miss out on all the Ford-bashing fun to be had...He smacked that one too.
He did this pinball thing three times. Right in front of me. I almost did the same thing because I was laughing so hard.
He was going under 30, but I still stopped to make sure he was OK. All he said was "d### anti-lock brakes don't work worth a s###!"
Yeeeeah, anti-lock brakes. Tell that to the dealer pal.
Made a soup sandwich out of that little truck. Plastic all accross the road.
All the driver assist systems in the world will not protect the confident stupidity of some people. :D
yo--can't fix stupidity--been saying it for years :D
I have been saying "you just can't beat the stupidity out of a man no matter how hard you try....But you can certainly beat it INTO him".
Too bad the dude had to learn the hard way, but no amount of ABS or other man-made gadget (short of jet assists) is gonna help you when your vehicle's inertia has completely overcome what little friction there is left!  :cheers:
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
