Changing the battery
Connect a temp battery up to the positive post in the under hood fuse panel, ground terminal to ground. You can also connect positive terminal of temp battery to the same spot the current battery positive cable connects to. You only need to use a 14 gauge wire.
    gdtaper
    gdtaper
  • Who's Online   5 Members, 1 Anonymous, 1,454 Guests (See full list)
