99 blazer leak at encoder motor
Got fluid leaking out bottom of encoder motor. It was replaced about 3 years ago at the dealer. Been leaking a little for quite some time. I had to add about 3/4 quart of fluid to transfer case to get it back to proper level. I looked back at my old receipt and noticed they only replaced the motor. Did a little research and noticed there is a insulator/gasket that goes behind it. They did not replace it. I guess they just used the old one over. 4 wheel drive is working ok. Any one have any experience working on one of these?
The parts diagram I looked at just shows the insulator which looks like it has a seal built into it.. Is the seal part of it? Or is an o-ring supposed to be back there? Doesn't show anything like a regular oil seal. I thing when I get a chance I'm going to pull it off and see what's going on behind it.
Does the needle bearing have a seal built into it? Cause the parts diagram's I've looked at don't show a separate seal. I'm on vacation in 3 weeks, I'm going to pull the encoder motor off and see what's going on behind it.
no ,the seal is in the transmission around the manual shift shaft ,,,
Thanks for info. I'm hoping their is a seal I can just pop out and replace and that the bearing is not loose.
    Enduro73
    Enduro73
  • Who's Online   1 Member, 0 Anonymous, 1,603 Guests (See full list)
