LS2 intake > LQ9 intake?
Found a good deal on a used ls2 intake, is it worth it for my lq9 mild build before I put the engine in? Any solid advantages?
If it is a LS2 truck intake off of a TBSS it is worth a little gain but not a lot
Is it worth $200?
Correction: it is a brand new intake manifold, and he also has a set of ls1 241 heads with ls6 springs for $300.. Worth the $500?
It isnt 200. Factor in rails, injectors, throttle body, x-link, injector pig tails, pcv re-route, and map sensor. You are looking at over $5-600. To me ig isnt worth it
sorry wrong thread. I've reposted in Chawkins6789's 04 Sierra 1500 Performance Build thread..
Chris,
I have very much enjoyed reading this thread from the beginning and seeing the work you've put into your truck; it's a beauty.
I'm going to start uprading a 2005 Sierra 1500 Z71.
Regarding your steering wheel upgrade: Was the necessary wiring already in the column? Was it mainly a matter of figuring out how to hook up the additional wiring for the buttons, or did you have to buy and add a wiring harness from an SLT etc?
Thanks,
Glenn
Need a clock spring from a truck that came with buttons on the wheel. Then dealership programming after it is all done
    bellssn690
    bellssn690
  • Who's Online   2 Members, 1 Anonymous, 458 Guests (See full list)
