Atlanta Predictions Anyone?
JonesNTN
I am betting on the 1st Victory for the Labonte/Mcswain Chevy combo. :werd:
That is what I am hoping for.  #18 rules. :thumb:
Make it a safe race and have either #24, #48, #25 or #5 win, and the rest finish in top 10 and I will say it was a good race!!
HMMM I dont know that much about nascar (boring as #### to me) but I will predict that the only cars that will finish the race will be 6,11,16,17,21,38,66,77,88,97,99,102,154  :cool:
Earnhardt Jr for the win. Jr's always run well there but has had something usually doom him in the final laps. Like debris flying into his eye, rain, blown tire, or the tv equipment rubbing a hole in his brake line. Its time to break his jinx there.
If not him I'd love to see Waltrip or Park win there. Specially Park.
I think that Harvick and Park will both have good top 5 runs and lead some laps but I think that Bobby Labonte will end up winning it.
I bet Park still gets cold chills when he goes around the Atlanta track. I wouldn't count on him being over-agressive this weekend. I don't blame him either.
####, I'm good! Couldn't have been better, and my favorite driver came in second.
I bet Roush is a little steamed adter losing all those cars to engine failure today.
