I think I would have
Wingnut
In the famous words of John Wayne (the Duke) as quoted in True Grit   In a response to Ned Pepper after Ned said "Thats pretty big talk for a one eyed fat man."
"Fill Your Hands You sonofab!tch" :crackup:   :owned:
