Install time for rear blocks?
30min. with impact, the trick is to not just drop the axle but remove the ubolts on one side and loosen the other, this way you can just slide the block in/out without having to fight the axle, quick and easy.
I assume you are installing a 2in. block?
Yes if you have two floor jacks and a impact it can be done in 30 minutes or less. I can do it in 15-20 minutes and not remove the tire.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 280 Guests (See full list)
