1976 GMC with a ZZ4 350 Crate motor in it.
Rod bearing in one cylinder has failed and now engine is knocking.
What type of bearings should I buy...shim pack...clearance tape? P.S. I only need one set of bearings...not bearing Kits...
Thanks.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
