Message center Light Flashing?
I have a 2000 z71 1500 4wd and my message center light has started flashing through every code on it. I hook up a code reader and it says no codes. Everything still works normally on the truck, just wanting to get this fixed. I am thinking it may be a ground wire issue, but not sure on that. Here is a short video of it flashing.
http://vid171.photobucket.com/albums/u288/BigBassMan_2007/001_zps5lu2ra7d.mp4
Your IPC is junk ,
I've never seen that before , there is no codes because it's not giving you a message , besides you still have a separate CEL
Put tape on it
That's a strange one. I'd suggest checking the truck's main grounds, as well as the IP cluster ground. Probably wouldn't hurt to unhook the negative battery cable for a few minutes either.
I unhooked the negative ground on the battery for 1 hour and it still doing it. I have been trying to check all the grounds so far with no luck. I figure it is something simple, but hope I find it soon. Thanks for the replies!!
I just changed out the heater core a month or two ago. I think I hooked everything back up right. Not sure if that has anything to do with it or not.
You did nothing wrong .... The IPC IS junk they all are in those few years
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,006 Guests (See full list)
