No speedo and tach
I just changed the shift solenoids in my 95 gmc 1500...I go to start the truck and speedo and tach aren't working and the gear indicator is not lit up orange...this has happened before and I thought it was because the shift solenoids were bad but I have the same problem with new ones installed...also can't add fluid to refill the tranny because the reservoir is still full even though I drained the tranny to drop the pan....any and all help will be greatly appreciated so thanks in advance
Ok ive been doing some research and read that the ignition switch can cause the same types of symptoms i had with my truck...
no speedo and tach
starting in 2nd gear (limp mode)
no transmission fluid pressure
gear selector will move to different gears but will not move no matter how high it revs
I know im new on here but any help would be greatly appreciated...thanks in advance...
    Dig Deep
    Dig Deep
  • Who's Online   4 Members, 0 Anonymous, 640 Guests (See full list)
