Oil pressure gauge
Hello all,
I replaced the gauge cluster a couple of years ago due to the speedo not working, and recently the oil pressure gauge reads max.(80 psi)when the key gets turned on.
How do I troubleshoot to find out if its the gauge or sensor?
Thank you,
Tony F.
maybe this is my answer....
The stepper motor is what moves the needle on the gauge in the dashboard. Usually when those go out the needle goes off the scale and doesn't move when you turn the key on or off. When the sending unit goes bad a lot of times the needle will move from 0 to 80 psi when the key is turned on, even if you don't start the engine. As the poster above said, a scanner with a data stream will tell you for sure.
Best way to test the cluster is with a cluster gauge sweep which would have to be done with a scan tool (not a code reader but with a full scan tool). If the gauges all function correctly, then that would rule out the cluster. If the oil pressure stayed pegged, then the oil pressure stepper would be dead.
For the gauge, a mechanical oil pressure test would just verify that there is oil pressure. But, if the cluster tests fine and the gauge sweeps, then the pressure sender would most likely be the culprit.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 254 Guests (See full list)
