Brake Controller and aux power
Installing an after market brake controller on a guys 2014 Sierra. He is getting the pigtail from his GM dealer. Does the 12v power supply to the trailer need to be hooked up under the hood as in my 2011 Sierra? Also needed to install a fuse as well. Any help would be appreciated! Thanks.
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 580 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
