Winnabego Motorhome problems
timk49
A family friend who is a 70 year old woman is having a problem with her 30 foot Winnabego . The Chevy 454 motor backfires when she hits a grade and suffers some loss of power. She said the problem started on her last trip after she had the transmission rebuilt. The engine has 50,000 miles on it all touring miles with lots of of mountains grades climbed. She wants to go to South Dakota in June but doesn't know about the motor problem. She is ready to throw a new engine in it. Any ideas or suggestions. I'd like to give her some advise but I don't know motors that well. Are there any problems with the 454 in motorhomes? Thanks in advance guys .
Tim K
50,000 is low mileage for that engine if it's had oil changes and similar routine care, and backfiring under load doesn't sound like a "replace the engine" sort of problem.
Might be nothing more than a timing or vacuum problem, perhaps something as simple as a broken/disconnected vacuum hose.
What year is the engine --- fuel injected or carb --- any "Check Engine" lights lit....   ?????
Some regular maintenance may be needed also. We had that same proplem before and it was due to a combination of bad gasoline and a needed fuel filter change. Also ran the sea-foam through it and everything was great again.
......it was due to a combination of bad gasoline and a needed fuel filter change.
The fuel filter is certainly among the things I'd look at, since lean running (fuel starvation) can be a cause of backfiring.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 443 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
