Full console USB connections
any chance someone could give me the detailed instructions on how to get the USB ports in the front of the full console working after a swap? Ive read through the FULL CONSOLE SWAP thread but can't find any definite answers as what to do to get just the USB ports to charge, i don't need them to display anything on the screen or anything. Any help here would be awesome as I've been battling figuring this out for a while.
any help with this would be awesome. I really want to get these things working to charge at least.
Hey schlegle1,
I read the full console swap on a slow work day and I'll be honest, I don't remember exactly how it was done. But I think one of the guys purchased the usb cable that plugs into the HMI or the radio behind the dash (i honestly cant remember) and had to trim the plug for it to go in. GM #19303328. I think they then had to make a custom fitting to the center console where the usb's are. Sorry I couldn't give you more info, but maybe u can search that thread for the part number (which is where they discussed the usb charging).
thanks, yea i couldn't find anything that gave me a straight answer as what to do step by step. I read a bunch of random things but nothing that said "do this" you know what i mean?
Yeah... I was trying to find the huge thread because it was nearly 60 something od posts.... But also I found this part number that may help you as well... this was another part I believe one of the guys working on that build used....: USB Connector Terminal tray #27: SAIT-A03GF-M064
Maybe that will help but if you have the link to the thread I can find the user I can spot his pic that did it successfully and you can PM him.
