ABS problem
I have a 99 K2500. I just replaced the front rotors and pads, but have developed an ABS issue. At 5 mph, the ABS activates. Is this common? Any suggestions on correctling this?
I have the same problem('00 Silverado),  I think it's the speed sensors.  The Autotrac also seems to engage on dry pavement now.  It is getting worse, not better.
Any fixes?
:thumb: I found this on a post on this site...
Check this out - SB 20525006 I think it applies to your '99 not my 2000.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
