2000 GMC Sierra Keyless entry issue
Just trying to verify if my BCM is bad or what the problem could be? One day last week my keyless entry quit working. Key fob is less than a year old. Changed battery, still nothing. Tried to reprogram it but when I follow the procedure of turning the ignition key On, Off, On, Off then releasing the power unlock button my door locks don't cycle thru lock and unlock. I hear what sound like the solenoids actuating but the actual locks don't move. It's like they aren't getting enough voltage to the solenoids. I then tried to program the key fob holding the lock and unlock buttons down for over 30 seconds after going thru the procedure but nothing happens. I've also noticed now that when I push the power door lock button on either door to "lock" the drivers door lock slide will either move weakly to the lock position or not at all. Anyone else ever have this issue?
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
