Serpentine belt squealing 04 Yukon XL
You are correct, I didn't check alignment properly, I just eyed it up with a straight edge. I was sure the pulley was pressed on all the way because I couldn't get it pressed on any further until I removed it and saw the problem.
The pulley surfaces are not the same offset from the ridged belt area so putting a straight edge across the power steering pulley and extending it to the harmonic balancer or alternator pulley didn't show anything.
I didn't think to measure from the straight edge to the first rib until this time when I again suspected the power steering pulley.
The power steering pulley is the only one that can be out of alignment. It is pressed on after the pump is installed. All the other ribbed pulleys are bolted in place and not able to be out of alignment. (Unless you put a washer behind the bearing)
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 450 Guests (See full list)
