cab lights wiring harness
I am installing 2015 gm cab lights on a 2006 duramax that has never had cab lights. Does anyone know which wiring harness I should use for this application? I'm sure the wiring harness meant for 06 will not have the same plugs as the 15 cab lights. Any ideas? Trying to have as few splices as possible. Thanks
The 06 plugs into the panel behind a triangle cover on the right side of the dash, I believe its the bottom open connector on the small board. you can get that harness used cheap and just splice in the 15 set up. just 2 wires
    BigJake
    BigJake
  • Who's Online   1 Member, 0 Anonymous, 565 Guests (See full list)
