Chainsaw repair help?
Anyone know anything 'bout chainsaws?
Have a cheapo Poulan "Wild Thing", I think around 2.2 cc and 18" bar.  Used it the first time Monday to clear brush and trees blown over in tornado.  Ran great for a hour or so, turned it off for lunch and then tried to restart.  The starter cord will NOT pull more than 1 or 2 inches out.  Checked the bar oil and it was little less than half (chain looked really dry tho).  Added oil to the top, topped off the tank with the correct 40:1 oil/gas mix and still no pull.  Chain "rotates" manually so I don't think the sprocket or whatever is seized.  Tried to pull the plug and could not get it loose.  Man it is in there tight!!  Tried various combinations of trigger holding whilst starting 'cause I know there are some safety features that might disable the saw.  Nothing works.. Any suggestions as I have alot more cutting to do this weekend.  Thanks guys.
That's what you get for buying Wal-Mart junk. (I don't know where you got it, I ust know Wal-Mart carrries the"Wild thing")
Go to a Sthil dealer and get yourself a REAL saw.  :chevy:  Just Kidding
If it has a kick-back shut-off, make sure that is shoved forward.
I have a Poulan Pro model that I have been using for 13 or 14 years now. It has never been touched mechanically. I have worn out 2 bars and about 25 chains. Good saw for the money.
:chevy:
Cheap LOWES junk, but point well taken.  Never expected to do more than tree trimming around the house with this thing.  I full well realize it is just a toy saw, as I have used dads "farm boss" for years.  But, I had to use something other than my teeth, didn't I ???
Anyway, I jammed that guard/handle thingie as far forward and back as it would go, but it never really moved, or clicked, ya know?  I mean it didn't really do anything - just bend!!  Thanks for the replies, I might have to resort to my chompers anyway :(  :banghead:
BTW, the engine size is 40cc, not 2.2cc's.
BBTW, check out what Poulan sez about this "wild thing":
"Wild colors and superb performance will
    help tame the toughest cutting tasks"
Oooh, I am so glad that purple works so much harder than green to cut trees.
This may sound stupid or even obvious, but with my Poulan 'Anniversery' model  (18 in bar), whenever I have trouble starting it, I cycle the red on-off switch a few times.  On mine, it is on the case right were you can accidentally pop-it off with your thumb while working.  I have also found that sometimes it will not shut off the engine either unless I cycle the switch a couple of times. One of these days, I will replace the switch.
This is most prevelant when I've been using it for a while.  If this switch is stuck in the 'off' position (internally), you will never start the thing.
Other than this, mine has worked flawlessly while going through 2 bars and at least 10 chains.
Thanks, bummed, I will try that when I get home.  Seems that the cord would at least pull even with the switch off.  Dunno, I'll try anything at this point.  It really seems like a safety catch or something.  Who knows...
sounds like you might have knocked on the kickback safety thing on when you put the chainsaw down or something.  It works by immediately stopping the chain from moving.  That could possibly keep the rope from turning the engine over.  Try messing with the kickback thing some more.  Or maybe take some of the side panels off and see if some wood or something is lodged up around the mechanics.
Does it turn over at all?
It's possible that the piston is frozen at TDC, which would make it almost impossible to turn over.  Of course the only way to see if the motor is at TDC would be to remove the plug...
If nothing else, dig up the receipt, and take it back to Lowes.  Poulan makes a good saw for the avg guy.  I think they make all the Craftsman saws (at least my old one).
Poulan is a good saw for general work but it sounds like you got a bad one.  I don't believe that model has an actual chain brake, just a hand guard.  I may be mistaken on that.  It sound like the engine seized up, bad news.  Take it back and get another Poulan.
Thanks everyone for the suggestions.  I think I will try to break the plug out again tonite.  It makes me wonder if the piston maybe struck it so hard as to wedge it in there real tight.  I does feel like it is seized - bad news, I guess.  If thats the case, we will see what Lowes will do for me.
:chevy:  :)  :(
If they do, they did a good job w/ those.  We have a 24 year old Craftsman that still works well.  It was used on our farm when we lived out in the boonies, so it has not had the easiest life.
:chevy:  :)  :(
You probably shouldn't try to get the plug out.  Be sure the fuel in your tank is in fact mixed correctly before it goes back to Lowes.  If it is seized and has the proper fuel in it they will honor the return with no argument if it is like our local Lowe's. A seized engine is usually caused by a very lean mixture or a lack of oil in the mixture.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 546 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
