Electric fan runs all the time now???
2009 GMC Sierra 5.3, 90k miles
Lately, every time I start my truck both the low and high electric fans start running within a minute. They'll run for a few minutes then shut off, then cycle back on a few minutes later. Not sure what's causing this. The temp gauge has never budged like the engine is getting hot.
Did a little troubleshooting by removing the relays and noticed that when I did the a/c stopping cooling. Not sure the relation to this??
Anyone have any ideas?
Chiming in and paying attention to this one..
Different body style.. But my 03 1 ton has done this for about 8 years.
If your AC or defrost is on the fans have to run to cool the condenser and alleviate the head pressure on the pump.
But why all the sudden does it do it now? Especially in the winter??
Those fans hardly ever came on before. Only in the extreme summer heat.
  • 3 weeks later...
Quick update,
I've ruled out the a/c.
I've started the truck with the a/c off and the fans still come on.
No one else has had this problem?
2009 and all the sudden having all kinds of problems...
-transmission is down-shifting like its about to fall off the truck
-sometimes I have to wiggle the key to get the truck to start-like the Ignition switch is bad
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
