multi function switch trouble
:chevy: i have a 96 gmc p/u that has lost the cruise control and the low beams.i have tested and found the headlight problem to be in the stalk and expect that the cruise problem is that also.i was told this is common.does anyone know where i could find instructions on replacing the multi function stalk?thanks
That might be a PITA to replace .
I think you have to pull the steering wheel off to get to it once thats done there are some size 20 or 25 hex bolts in there
And a damn expensive part I think that one is about 200-250 dollars
I broke mine on my 97 (busted the hazard light switch off) and I just figured I would go with out it once i got the covering off the column i took a look at it and said no thanks :chevy:
K1500 is right I think... I believe you will have to pull the steering wheel.
I don't know if the part is quite that expensive though. I know they used to be outragously priced, but I think they are a little more reasonable now.
Shaners , price from local stealer was 203 bucks two weeks ago .
And I dont have the cruise on mine so I would imagine it would be more for the cruise .
My friend had one replaced on his Lumina a year or so ago, and with labor it was less than $200. He must have bought a used one from the salvage yard...
The steering wheel does not need to come off to get at the switch. It would make it easier, but not nessassary.
There are two torx screws that hold the switch on the column inner structure. One is from the top and the other points towards the dash, behind the steerng wheel on the left side, but you should be able to get to this by turning the steering wheel and maybe using a swivle joint on the socket.
We usually charge 2.5-3 hrs of labor, plus $200.00 for a new switch from GM (turn,cruise, tilt.)
If you take your time, you should be able to do it without a problem. Good luck.:cool:
great,thanks for the help guys.does the wiring unplug from the switch there at the top or do you have to fish the wire?i can get the switch for 170 bucks with my gm discount.the dealers want 330 for the switch and over 200 dollars labor....whew
Don't quote me, but I believe the wiring unplugs...
There is most likely a rod that runs down the steering column to another switch for the High/Low beams. Make sure you get that rod back in it's original spot, or your high/low beam switch won't activate.
  • 8 years later...
Hello, I just bought a new multi function switch for my 1998 K1500 Silverado W/Cruise
and it was only $63.00 on EBAY shipping was free and it arrived in 2 Days from the day I ordered it.
The switch looks great and is an exact replacement for the original. My local parts houses were asking between $150 and $200 so I was happy to save almost $100.
Have a great day and good luck!
Paul
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,222 Guests (See full list)
