Anyone installed an aftermarket stereo
I have a 96 K1500 and have gone to extremes to combat the problem, but to no avail. The problem existed in my 92 K1500 with a similar setup. Just wondered if anyone else has beaten the problem and how did you do it?
I have gone as far as running 4 awg power and ground from the battery to the distribution block. The head unit power and ground even come from the distribution block to eliminate the possitility of ground loops. The rca's run up the a-pillar and above the headliner to come down the back panel and wrap around the rear window to stay away from all power wiring.
I have custom built cross-overs for my front speakers. I have a Focal home audio 7"dvc and a Focal T120K for the fronts and 4 JL 8W6's under the rear seat. Power comes from a Punch 200 and a Punch 400x4. Between the signal and the amps I have an Audio Control EQL and a 2XS. And finally, my signal comes from a Premier DEX-M88 with the add-on GEXT70 Tuner pack.
I love the sound I've got but that d**n whine exists and drives me crazy.
if you have a whine when you accelerate, chances are something isn't grounded quite right. Make sure you have a really good ground from your head unit and check the ground on the amps. Make sure where every your ground goes to, there is no paint on the metal or something like that. Try to stay away from grounding it straight to the battery too, that can cause a whine sometimes.
Also what kind of head unit is it, I had a blaupunkt(sp) and the SOB sucked, with the whine, when I swapped it out for a sony it went away.
Besides what has been mentioned, another source is the plug wires. Cheap or old wires or a high powered coil can cause noise in the head unit. GM is worse for this because the distributer is very close to the head unit. Good wires and cap will eliminate this.
tmf6902 - The ground directly to the battery was used to eliminate the possibility of a bad chassis ground. The head unit is a Premier DEX-M88. It was made in the mid 90's as Pioneer/Premier's top of the line unit. I can attest to the quality of the signal output based on personal experience tuning the stereo with an O-scope.
MarkD - All the time. Non stop drive me crazy noise.
Wingnut - Where exactly does that install? Does it sit directly behind the alternator?
EMC'S Z - It occured to me the other day that my power wire travels from the batter down the passenger fender and across the firewall to enter the cab under the master cylinder. Is that close enough to the coil and distributor to cause any interference? Is there any kind of sheilding that can be placed behind the radio in the dash to prevent any interference emited in the close proximity of the radio?
I would say that this is your problem.
Are your AUX terminals on the engine bay fuse box in use? If not this is where I would pull power from. There should be 2 terminals each good for 30 amps.
That should run at least the Punch 200 what is the internal fuse on the Punch 400x4?
Also where is the head unit grounded?
Worst case Run the power wire across the radiator and back to the firewall.
Also the shorter the ground the better.
Another check to see where the Whine is coming from:
Unplug the rcas from one amp(leave amp powered up) at the amp?
Goes away= not that amp, head unit or RCA problem.
stays (in speakers from that amp)=problem in power supply to that amp.
Repeat with other amp.
If it goes away with either amp, to check RCAS:
leave rcas pluged in to amp and disconect at supply.
Stays = RCA routing.
Goes away= source.
Repeat process untill at the head unit or you find the source. Then You can Isolate the cause easier from that point. Trying to guess on the whole system is a stab in the dark and can be frustrating and very time consuming.
Let us know what you find. I am positive that we can fix your problem without one of those noise suppression thingies :thumbs: .
As far as Shielding the radio should not be required. Proper wire routing and GOOD wires and cap should not cause this wine.
Good luck and let us know what you find.
Eric
It installs in-line, between the alternator and the battery.
I used one on the neighbors truck, after he did most of the wiring half-a$$ed. I wasn't about to track down all his wiring mistakes, and correct them. So I threw one of those on there. Worked like a champ.
That said, there has been a lot of other things mentioned in this thread that could be the culprit, and you would be better off in my opinion, to find the problem...Not put the band-aid on the power wire.
It all depends on how bad of a case of the lazies you have when it comes to pulling apart your truck 93 times to find that whine....I had to redo about half my wiring to fix it.
Hope this helped.
-Nut
Try installing a $15 ground loop isolator on the RCAs. Got mine at Radio Shack.
I has the same problem and spends hours playing with wiring as people have outlined above to no avail. (the truck was a dodge). Bought the isolator and noise problem was gone. There appeared to be no sound quality loss. If it a competion stereo the hours of agravation may be worth it to find the source but for the regular joe like me (maybe you?) the GLI will work just fine.
When I install my next stereo in my Yukon and if the whine is there, the thing I'll do will be to buy and try the GLI to save the hours of hassle. Obviously it won't solve the problem if the whine is power side related and not signal but it is a cheap place to start and could save hours.
I RAN THE POWER WIRE AND GROUND UNDER THE CAB.I FOUND WHERE THE REAR SEAT BOLTS WERE AND PUT IN A STUD.I PUT MY GROUND WIRE TO IT.RAN THE HOT WIRE THROUGH THE VENTS IN THE CAB.I GROUNDED MY AMP,CAP,AND EQ TO THIS.THE STEREO IS GROUNDED TO THE FACTORY HARNESS.TURN ON POWER FOR MY AMP RUNS DOWN MIDDLE OF CAB.RCA;S RUN DOWN PASS SIDE. YOU CAN RUN SPEAKER WIRE AND RCA;S TOGETHER.IF THEY MUST CROSS POWER AND SIGNAL CABLES THEY NEED TO CROSS AT 90 DEGREE ANGLES.YOU MIGHT WANT TO CHECK WHERE YOUR RCA CABLES RUN IN THE DASH. :sigh:
I had the same problem and never could get it out with the KOSS MP3 player I had. It went bad and I replaced it with a JENSEN MP3 player and the problem went away. I think some of it has to do with the radio. :D
  • 1 month later...
I have a Pioneer 8400MP deck with alpine speakers in the front and boston accoustics in the rear, and there was no whine. When I recently installed my Rockford amp and sub, I got the same whine. I think it has to do with the power cable running to the amp, but its possible that its from the RCA's... I'm using all high quality rockford cables, and my wiring job is good, just got unlucky I guess. The same thing happened when we installed an amp for rear speakers in my friend's VW Golf GTI, the whine only happens in those speakers.
I think the alternator noise filter sounds like a great idea, think I'll pick a couple of those up for my truck and my friend's Golf.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
