MorI moto 2stroke l.e.d
Anyone have reviews on the Mori moto stroke l.e.d head light bulbs...
According to the website they put out 5000 lumens which is more then my mori moto 5k h.i.d if this is true I'm tempted to throw out my h.i.ds for the l.e.d reliability. Does anyone have any experience about the bulbs yet.
